Testing and Results
We place our test rigs under load using the Small FFTs stress test in the free application
Prime95, as this test is designed to place maximum load on the CPU and minimum load on the system's memory. We use the freeware application
Core Temp to measure the temperature of our CPUs, as it reads data from the DTS (digital thermal sensor) embedded inside each core of Intel's modern processors and thus provides as accurate a reading as possible. We always take the temperature of the hottest core for consistency, and do so after 15 minutes of the Prime95 test, which is enough time for temperatures to plateau.
The results provided are the delta T results; the difference between the recorded CPU temperature and ambient temperature at the time of testing. Our labs are not temperature controlled, so this provides the most accurate method of comparison for coolers tested on different days.
Any cooler that causes one of our CPUs to hit its Tj Max, the maximum temperature at which the CPU will operate before downclocking itself, is considered a fail. If a cooler has multiple available fan speeds, we retest at appropriate speeds to highlight the differences. Unless otherwise stated, closed loop liquid coolers are installed with their fans as exhausts. Finally, any cooler that is PWM (pulse width modulation) capable is tested both at full speed and using the standard PWM setting on our motherboards.
Intel LGA1155 Test System- Intel Core i7-2600K overclocked to 4.4GHz (44 x 100MHz) using a vcore of 1.275V
- Asus Maximus V Formula
- 2 x 2GB Crucial Ballistix 1,600MHz low-profile RAM
- PNY Performance 60GB SSD
- Corsair HX750W PSU
Intel LGA2011 Test System- Intel Core i7-3960X Extreme Edition overclocked to 4.2GHz (37 x 113.5MHz) using a vcore of 1.275V
- Asus P9X79 Pro
- 4 x 4GB G.Skill Ripjaw 1,6000MHz RAM
- Samsung SSD 830 128GB
- Enermax Revolution 87+ 750W PSU
Both systems run Windows 7 64-bit, are built inside a Corsair Carbide 500R and use an AMD ATI Radeon HD 5770 1GB. Coolers are tested with both of the case's side panels fully attached and with its two 120mm front intake fans and rear 120mm exhaust fan operating at consistent speeds, providing interior airflow that is more realistic than a benchtable or our previous set-up. The cases have been cable tidied and had their front drive cages removed to optimise airflow.
NZXT Kraken X60 (Maximum profile)
Corsair Hydro H110
Corsair Hydro H100i (Maximum profile)
Thermalright SilverArrow SB-E Extreme
Noctua NH-D15 (dual fan)
Corsair Hydro H105
Antec Kühler H2O 920 (Extreme profile)
NZXT Kraken X60 (Silent profile)
Phanteks PH-TC14PE
SilverStone Tundra TD02
NZXT Kraken X40 (Maximum profile)
Noctua NH-D15 (one fan)
Corsair Hydro H80i (Maximum profile)
Corsair Hydro H100i (Balanced profile)
Corsair Hydro H105 (PWM)
Noctua NH-D14
SilverStone Tundra TD02 (PWM)
Thermalright Archon SB-E X2
Corsair Hydro H75
Alpenföhn K2 Mount Doom
Noctua NH-D15 (dual fan LNA)
Zalman Reserator 3 Max
Antec Kühler H20 950 (Extreme profile)
Thermalright SilverArrow SB-E Extreme (PWM)
Noctua NH-D14 (low noise adaptor)
Phanteks PH-TC14PE (PWM)
Raijintek Ereboss
SilverStone Argon AR01
SilverStone Tundra TD03
Corsair Hydro H80i (Balanced profile)
Antec Kühler H20 650
Noctua NH-D15 (one fan LNA)
Corsair Hydro H75 (PWM)
Corsair Hydro H90
Noctua NH-D14 (PWM)
SilverStone Tundra TD03 (PWM)
Cooler Master Seidon 120M
Alpenföhn K2 Mount Doom (PWM)
Thermalright Archon SB-E X2 (PWM)
Be Quiet! Dark Rock Pro 3
Gelid GX-7 Rev. 2
Raijintek Ereboss (PWM)
Thermalright True Spirit 120M
Corsair Hydro H80i (Quiet profile)
Antec Kühler H2O 920 (Silent profile)
Alpenföhn K2 Mount Doom (7V adaptor)
Corsair Hydro H100i (Quiet profile)
SilverStone Argon AR01 (PWM)
Zalman Reserator 3 Max (PWM)
NZXT Kraken X40 (Silent profile)
Noctua NH-D14 (PWM; low noise adaptor)
Deepcool GAMMAXX S40
Phanteks PH-TC12DX
Antec Kühler H20 950 (Silent profile)
Gelid The Black Edition
Thermalright True Spirit 120M (PWM)
Noctua NH-U12S
Raijintek Pallas
Gelid GX-7 Rev. 2 (PWM)
Raijintek Pallas (PWM)
Gelid The Black Edition (PWM)
Arctic Cooling Freezer i30
Noctua NH-U12S (low noise adaptor)
Gelid Tranquillo Rev. 2
Deepcool Gamer Storm Gabriel
Deepcool Gamer Storm Gabriel (PWM)
Thermalright AXP-100
Thermalright AXP-100 (PWM)
Zalman FX100 Cube
Intel Stock Cooler
34
36
37
37
38
38
38
38
38
38
39
39
40
40
40
40
40
40
40
40
40
41
41
41
41
42
42
42
42
42
42
42
42
43
43
43
43
43
43
44
44
44
44
44
44
44
44
45
45
45
45
45
45
46
47
47
47
47
47
49
49
50
51
52
52
55
56
58
69
79
20
30
40
50
60
70
80
Delta T (°C) (lower is better)
Corsair Hydro H105
Noctua NH-D15 (single fan)
Phanteks PH-TC14PE
Corsair Hydro H110
Corsair Hydro H75
Noctua NH-D14
Noctua NH-D15 (single fan LNA)
Corsair Hydro H90
Phanteks PH-TC12DX
Corsair Hydro H80i (Quiet Profile)
Noctua NH-U12S
Raijintek Ereboss
Raijintek Pallas
40
42
42
43
43
44
44
45
45
45
46
46
46
47
47
47
47
47
48
48
48
48
48
49
49
50
50
50
51
51
51
52
52
54
54
55
55
55
56
57
58
59
59
60
60
60
Read our
performance analysis on the next page.
